Planning to install A/C in bedroom. It is in 2nd floor of the appartment and there is 3rd floor above my apt. Not much direct sun light as the window is on south wall. Also have blackout curtains on windows. So need some suggestions on deciding the capacity and models. The size of the room is 12.8ft x 11ft ( 141 Sqft ). But on one wall there is wardrobe which is from floor to ceiling ( floor area 15 sqft ). So for the A/C tonage calculation I have deducted this from 141sqft. So effective open space is 126sqft. Is this the correct or should i consider 141sqft for the tonnage?. What would be the tonnage needed? The sales person told 1 Ton for 120sqft is fine. Will it be better if I go for 1.5T capacity?
After going through some older posts shortlisted Daikin and Panasonic models.
Went to the nearby showroom and sales person showed the 2019 panasonic model which has Nano-e air purification and ag filter. He told in bangalore A/C usage is limited to mainly summer months and then unused/minimal use rest of the year. Since this model is with in built air purification in nano-e mode, it can be used throughout the year in case only air purification is needed.
This was the model on display ( Inverter 3 star rated, 1 Ton ) (
Daikin model with similar features are only in 5 star inverter and the price is higher than panasonic. Daikin offers 5 yrs and panasonic 10 yrs warranty on compressor. Considering all these factors I am more inclined to Panasonic models. I am open to other brands also within 45k budget.
Please provide some feedback if anyone uses similar panasonic models. ( Reliability, Noise level, Power consumption , Effectiveness of nano-e and purification technology etc ).
Panasonic 3 Star Split AC (CS/CU-WU12VKYF)
Panasonic CS/CU-WU12VKYF, an 3 star split AC comes with Nanoe-G technology, Aerowing, 4 way air swing, PM2.5 Filter, Ag Clean Filter, Powerful Mode & more.
www.panasonic.com
