Nairrk
FiiO BTR17 is a versatile, high-performing Bluetooth DAC and headphone amplifier designed for audiophiles demanding premium sound quality and functionality.
The BTR17 features a 1.3-inch IPS display with a sharp 240×240 pixel resolution. This screen provides clear and detailed information about the device’s settings, making it easy to monitor and control your audio experience.
Equipped with the latest QCC5181 Bluetooth 5.4 chip, the BTR17 supports advanced audio codecs such as LDAC, aptX Adaptive, aptX HD, and more. This guarantees high-resolution audio streaming with low latency, making it ideal for wireless listening without sacrificing sound quality.
For headphone connectivity, the BTR17 includes both a 3.5mm single-ended and a 4.4mm balanced output. The 4.4mm jack is more robust and durable than its predecessor, ensuring reliable connections with high-end headphones. This versatility allows you to use the BTR17 with various headphones without compatibility concerns.
Read
