Dear All,
Happy to report that the Emotiva-Fedex-Borderlinx-DHL-RCS Courier (the last one was scary) chain did not break and I have safely received the components and set it up. Music is all over the place, too many things to write, which I shall do slowly... right from purchase to setup. For now some pics. There is a sub which is hidden under the cabinet and cannot be seen. The sub is Sony (don't be surprised
), it is 8.3 kgs heavy stuff, 200 RMS bass reflex with 20cm driver, beefy powerful amp, goes down to 38 Hz, I have set the low pass filter at 80Hz in USP-1, and I realized that the 12L2 needs very little help from the sub, it is receiving the full range signal so in all it sounds like a 2.5 way set up. One thing is I will need attenuators of -6 db, do we get them here in India? I would prefer the harrison labs ones. The reason mostly is, that the input sensitivity of the power amp is 1.1 V whereas USP-1 output varies from 2.2 to 7 so need to tame it down a bit, but the biggest change is, I am not missing tone controls! I am able to listen to old hindi movie songs to Enya to Yanni to Techno, great stuff, huge improvement really, much understated in this age of what hifi reviews and advertisements. I shall also submit an article on watts and capacitance sometime, to take a stab at the much hyped wattage battle
PS - the remote is special.. weighs 0.5 kgs.. all aluminium body and steel buttons, to change batteries, you need to remove six screws and then put it back, solid build quality there
