Hi Guys,
This is my first post here, I need your help
Ive always wanted to setup a home theatre and never went about it, (at the moment Ive got a 22 Samsung LCD, while my pc monitor is a benq 24 lol), I have reading up a lot and just overwhelmed at the info esp with the audio,
I will list down my requirements first,
50% regular TV (HD), 30% movies & hopefully the rest is some gaming if my missus allows it every now and then
The room size is around 19 feet in length and around 12 feet in width, the seating position is sort of half way with two couches with their back to each other
3 sides are just walls and one side is just glass/wood screens from the top to the bottom overlooking the hallway
Been saving up and will have a good budget around 2.5 to 3L by May 2014 and probably increase it more further if its worth it.
Looking for a big screen prob 50 or more
I did browse around for a much bigger TV, Ive looked and liked the 55 screen from Sony 850A around 1.5L i guess its good?, I was led by the guy in croma to sit in the bose booth and honestly my expectation and what I heard was absolutely shit, all that I heard was loud nothing more...
Like I said before I have been reading up, Im pretty sure I have misunderstood almost if not all concepts, I desperately need your assistance to help me understand and guide me,
Speaker -> 2.1, 5.1, 7.1 (.1 sub woofer), 7.1 does not usually make sense since most codecs (?) dont actually have content in 7.1, 5.1 is best/more than enough for home theatre
Sub woofers -> Low frequency, gives best output for all those actions scenes and explosions
Floor standing -> 4,3,2 way etc. Four way give output for low mid low, mid high and high frequencies, Three way allows for frequencies low mid high, and henceforth two way is lesser, For best home theatre floor standing is the way to go
Floor standing > book shelf speakers in general I guess when rooms are smaller book shelf is best way to go
Centre channel speaker takes care 50% almost all of the dialogue
Bipole speakers are best for surround sound?
The concept of speakers is the listener shouldnt know on which speaker he is actually hearing from?
A good speaker shouldnt be hollow as you knock on the wood?
No AVR can drive speakers to their Max potential, an amp is required?
AVRs process audio but does pre-amplification?
A pre-out is required on the AVR if one wants to use a separate amplifier?
THX certified, does that certification guarantee a good experience when it goes to identifying products?
Speaker last a life time, AVR is like a computer with more frequent changing technology, worth more investing in speakers than an AVR
Speaker wires -> lesser the gauge better the thickness and quality, balloon connections are actually worse than using the wire?
Bi amp -> connect two speakers on the AVR to a single speaker?
AVR setup > HTiB
3D technology although active 3D is better it causes more headaches, passive is cheaper and more easy on the eyes
Different ways of investing -> buy an AVR and start off with a 2.1 and then expand, buy a HtiB?
Auditioning has its pros and cons, con being most guys use shit AVR
I have been looking around, keep in mind Ive not auditioned anything yet which i will do
Sony 850A -> good, bad or better? Any other choice
Polk audio -> RTI A7, polk gr8 for Home theatre?
Subwoofer -> Please suggest?
AVR please suggest? Ive also heard that Polk speaker (A7) needs an amp to hear it best, what would be a AVR with pre out?
HELP!!!!
AVR setup > HTiB
HELP!!!!
		 hyeah:
hyeah:
 So you got me wondering which one was true..  Sorry about that.. Good luck on your hunt for HT... Sometimes you'll find no advice but when people chip in, it pours... So keep exploring and do audition whenever possible.
