gvgirish2901
Hi Folks!
I live in a city called Hassan in Karnataka, India where the nearest Private FM radio station is 120 kms far; that is in Mysore, Karnataka. Hassan has its own AIR with 102.2 Mhz though. But I love listening Private FM Channels which are 92.7 Big FM and 93.5 RedFM which gives some variety.
I connected my 15 years old BPL Tuner into a car Antenna and mounted it on my terrace on a 5ft long Plywood strip. I managed to catch both signals of 92.7 and 93.5 FM but with some noise that is 60% signal with another 40% noise. So, I am planning to buy a Omnidirectional FM antenna in Amazon from Stellar Labs [Link: Buy Outdoor Omnidirectional FM Antenna Online at Low Prices in India - Amazon.in ] which sources from USA. So what is your suggestion guys? Is it worth sourcing the antenna which I feel will give better reception than present Car FM Antenna or Shall I improve this present Antenna by whatever means you folks suggest? Or Shall I invest on a better tuner.
In Hassan, the radio signals catch pretty decently in my Car Stereo without distortion and Noise. I am waiting for you advice guys.
Thanks in Advance
Thanks in Advance
