mailrishigupta
Hi guys......
I asked Bass & treble in gurgaon to suggest a good sound system.......
They suggested the Focal Sib and Co 5.1 for ~40k plus the denon 1312.....bringing the total to about 60K, which is a little too much for me.....(I was thinking around 40k total).....
They also suggested the Polk audio RM6570 set(containing the speakers and the denon 1312) around 45k......
My room is ~20x20 feet, and i want to primarily watch movies.....
My question is, is there a significant difference between the two, worth the 20k difference......
also if I am to indeed spend that much, are these the best sound systems at 60k and 45k respectively....?? Or are there any other combinations you would suggest? (I need the set to sound good, even if it comes with fewer "features" like the number of video inputs etc)
