For Sale : Clearence- Stands and Rack
magma
Following items are for clearance -
Some were made just because i was curious and one item is surplus ( was made in bulk. 2 remained , hence put up here)
1. Speaker Stand "Opal" : A classic speaker stand, 25inches height , 6mm thick top and bottom plates, 2.5mm thick Steel column sand fillable. Black matt premium finish.Top adjust SS spikes.Approx 12-13kgs/pair.Recommended speaker weight 6-20kgs/speaker.This is basically a watered down version of the popular SAL alif
Top plate 6*8", Bottom 10*10"
Rs 5000
2. Speaker Stand "BW Single" : Budget Speaker stand with single Aluminum extruded oval sand fillable column.6mm thk top and bottom.Top adjust SS Spikes,.Recommended speaker weight 4-15kgs/per speaker
Top plate 6*8", Bottom 10*10".Height 25inch
User will be provided White river sand complimentary
Rs 4750
3.Beta Rack : 6mm Black Toughened glass shelves. 19mm Black Wood Base shelf.Total Height 32-34 inch.For more info visit Sound Foundations - Homepage
Topmost shelf will hold a 17-19 inch LCD if reqd ( not recommended for heavier equipment). Base dimension 24*18 inch:
Other shelves 17.5*14"(i need to confirm this though)
The rack is ready - however the toughened glass shelves will be ordered when you confirm your order
QTY : 2 nos
Price
Rs 11,500 (1 rack)
Rs9,500 (1 rack)
(.The level in the arms of the brackets are off by 1mm or 2mm however this doesnt matter since each bracket has leveling screws which allow you to level the shelves to perfect horizontal in any case.Also groove in the central column has a slight taper so you have to jiggle the brackets a bit to mount them.
I would be more comfortable if a mumbai buyer sees and buys this so that any confusion or untoward feelings are avoided.Obviously a mumbai buyer would further get shipping charges waived if its picked up)
If you are in a position to source your own shelving contact me for further deductions.Since it reduces shipping risks
Please keep the sanctity of the thread
Discuss only issues pertaining to this post
Contact via PM for further details/advice
Please note : above prices are clearance prices only , inclusive of shipping.Once items are sold these prices will be removed (with permission of supermod) and will no longer be valid for further orders
Above items are put on clearance since we, as policy ,do not make items for stock.We simply have no space , nor do we want to want to bring re stocking costs into the picture
Proceeds (after deducting absolute base costs i.e materiel and machining, NO labour ) as always to be donated to forum
Could you enumerate the differences between the two.
i have already mentioned in brackets!
THEY are the same rack
only one has a level difference in the arms(which can be corrected in levelling)and central groove has taper hence it is being offered cheaper
Hi Magma,
I note Capt. has reserved the rack quoted 11.5k, so please reserve the other one quoted 9.5k. Will send you PM for further queries. Will confirm later, subject to query-response.
Regds,
Sonsopshere
Hi Magma,
I would like to reserve Speaker Stand "BW Single" if no one has done so yet.
Please let me know the details for payment.
RgN1
2 racks have been blocked by 3 people
however there has been NO serious confirmation
obviously it will be first cum first serve to the serious confirmations
@Rgn1
BW stands has been temporarily blocked by a NON member yesterday
He has not yet paid or seriously confirmed
If you are seious please complete payment formalities
please mail me
email ID is Pmed
sono
i have not had the time to visit the factories today - hence i could not get the exact measurement
will do it tomm
as far as i remember the dimn youre looking for is 34inches
however the top column can be cut and shortened to whatever length you need if you think its gonna obstruct your TV viewing
Note to all (so there are absolutely NO misconceptions)
when this rack was designed aesthetics took precedence
the rack was designed for stealth - i.e the rack disappears when you load equipment on it
this is the reason why the shelves width is actually a few mm shorter than 17 inches
enough for the feet to be accommodated plus a little more for safety
it also has the most minimalistic look with the smallest footprint
In now way is this a high end audiophile rack like the alpha,gamma,theta,or raksang series ( which are obviously far more expensive as well)
it is a cantilever design with all its characteristics
Another difference is that the pics show a semicircular dome nut on each adjustable bracket
this has now been replaced by inverted spikes that are level adjustable ( so each shelf is individually isolated and can be independently leveled )
Neoprene pads will be given which are to be stuck to the underside of the shelf where the spikes make contact.The spikes pierce these pads and hence a non slip surface is created for the shelf
having said that you can see that one of my clients use these twin racks with equipment like a 60 kgs 300w rms classe power amp , an Acoustic research tube pre , a Q sonix music mgt system, A NAD receiver and a marantz CDP with misc HDD's etc
He is quite happy.
i think pics of his setup are on my website
OPal stand sold
BW stand sold
1nos RACK sold
details
rack footprint 22*17 not 24*18
size top to bottom tip to tip
34.5 inch
