Fosi Audio class d amps for JBL Control 1 pro speakers
You should be fine with any of those amps...
What's your type of application? Is it for a desktop setup?
Hi Premoddev,
Yes it will be for personal listening in a bedroom.
Will there be any issue with regard to impedance e mismatching ??...sound quality and loudness level ?
Thanks again for your reply.
Samml
Hi Premoddev,
Samml
You should be happy with either of those amps with the speakers you have mentioned... I guess you already have the speakers in hand and looking for amplifier now.
No ..planning to buy both.... the amp and the speaker .....any better speaker if you can recommend in 16 to 20k?
You can find better options like Mission LX2 MKII , Fyne F300 , Micca RB42, Yamaha NS333 etc. These speakers will be better built than the JBL Control one (Guess its with plastic body) and comes in around 20K..
You can check with Hifimart ( https://hifimart.com/product-category/speakers/bookshelf-speakers/ ). You may call them and ask for better price and also suggestion for under 20K speakers.
If you are okay with powered speakers, there are some good options like QA M20HD or Elac DCB41 (https://hifimart.com/product-category/speakers/active-speakers/ ). Those should be more easy to setup and less cluttered speakers with too many connection options, so you wouldn't require any separate DAC.
Thank you so much for your valuable response; will check the options
I have the Control 1 Pro, use them as speakers for my desktop computer. In a 20K budget for speakers and amplifier, I will not recommend the Control 1 Pro for music playback
How about Polk t15 premoddev?
Have you bought your amplifier? If the amp with you, better do audition with your amp and then select. Polk T15 is their cheapest offering mainly for HT surround duty. JBL A120 should be a better option in that range. Btw, these suggestions are solely from the reviews and not from my personal experience. That's why asking you to have auditions before purchase.
