Getting turntable at Ranchi
a.kr.sriv
Muri, india
Dear friends,
Please guide me, I want to get one entry level turntable. From where can I buy it. I live in Ranchi, jharkhand..
Thanks and regards
Srivastava..
Dear friends,
Thanks and regards
Srivastava..
Please let us know your budget so that we can recommend the best option to you. Do you already have records or you plan to get them too?
Budget is 30000/- max. I plan to buy records too.. Infact I need turntable, phono amp, and sound system(amplifier and speakers).
What is approx cost of tube phono preamp in india...
Regards..
Srivastava...
30K is a decent budget. Though, you missed a great deal only if you had been here before. Our FM, Shivam sold his Pro-ject Debut III in mint condition at a very attractive price.
However, about 2 months back, I got a mail from Nova Audio, dealers of Pr-ject in Mumbai, they quoted 22,800/- for project debut-III and about 17,800/- for 'Essential'. Phono stages from pro-ject start from 5400 INR
You can mail them : [email protected]
Pro-jects are really nice tables. They would be recommended along with Rega anyday. In case you want to go for a second hand table, you can check the classifieds in this forum. Good vintage tables at decent prices change hands often. Same for phono stages & amps.
Some LPs are presently open for sale in the section too. You can give them a look if they interest you.
In case you decide for a used table, you can go for Technics, preferably direct drives. They are solid tables and will out-last most of your gadgets!! Just a word of caution, make sure its in good working order and arm bearings & platter bearings are fine because in case you end up getting a bad TT, it will be a complete waste of money as spare parts for older tables are almost impossible to comeby and people who can service them are rare species these days.
Happy Hunting!
Happy Hunting!
Thanks for reply, one more thing, how to check the TT. Basically, what should be looked/observed during TT audition to get good info about bearings etc...
Regards..
Regards..
1. Look for a TT with solid build. If looking in vintage class, Pioneers, Sony, Technics, Garrard, Marantz, Thorens made excellent tables. I may have missed some due to availability and cost.
2. Check for speed accuracy with strobe lamp & with your ears too. There should be no audible 'Wow' and no speed fluctuations esp during loud passages of songs. Believe me, I have seen TTs whose speed dropped due to tonearm weight itself while playing. Not a bad idea to test roughly the torque by placing your hand against the moving platter. This will give you some idea about the torque of the drive.
3. Check /enquire about the cartridge & stylus with the seller. ALong with make, also try to know playing hours on it. Not a bad idea to change the cart with your preferred one once you buy any TT. So you may consider buying one without a cart.; if the seller is willing. This will bring down the cost of the TT as well.
4. Check the tone arm for any 'play' in it. It should be free to move in the perspective of playing a record, but there should not be any movement at the bearing point. Similarly, with the platter, you can give it a spin by hand to see if it rotates smoothly without any obstruction and in a straight line when looked from sideways. hold the platter on opposite ends of circumference & check for any unwanted play in it by lightly pressing it side to side.
5. Also, cosmetically good TTs indicate that they have been taken good care back in time, but should not be considered a tell-tale sign. If you are buying an automatic TT, make sure all toys work fine, else you know it will be difficult to repair, esp. if spare parts are needed.
6. Do not go for plastic made TTs mostly advertised on flipkart & on saregama website unless you are sure that you won't grow upon it and wont be upgrading it, as they are not upgradable in terms of cartridges and not sturdily built.
7. For the phono and amp, you may consider an integrated amp. It will save significant cost and sound decent. THere are many integrated amps with phono being sold in the 'for sale' section of HFV.
8. Last but not the least, invest in good speakers with good midrange. This will ensure that you enjoy the analog sound to the fullest. Personally I would advise against small satellite speakers & a big sub-woofer type set-up.
BTW, are you presently looking at any TT in or outside this forum? Keep up updated.
Saket
Saket
Thanks saket for this detailed guidance..
I basically don't know where to look for TT.
One offer from this forum is for akai AP 103 C belt drive, with amplifiers and speakers.
Another offer is about AKAI -APD30, direct drive, outside this forum...
By the way, what is "wow"? See my level of knowledge about TT's.
Regards...
Srivastava..
Regards...
Srivastava..
All music players depending on rotating mechanisms suffer from wow. Wow is basically inaccuracy or variation in speed. Turntables mostly suffer from this problem as their output is completely dependent on spinning records. This variation is expressed in terms of %age but only at factory exit. Over a period of use, wow can increase. But to enjoy the music, it must be below noticeable limits. Higher wow can lead to pitch shifts in music every now & then at some point of rotation. I hope now it should be clear to you.
About the TTs you indicated, I looked for the models on the net but couldnt find too much about them except that AP103C was sold with a cartridge and is a semi-automatic TT. I couldnt find any specs of the two.
If you are interested in them, give them an audition. Hear them for little long-say at least 1/2 hr. or more so that to ensure that no problem crops up when the TT runs hot. Some older motors can experience a speed drop when hot. Also there is something like intermittent failure in which systems fail when they become hot and again get better when they get cool.
& don't be shy of asking anything that you might not know. The objective of this community is to share knowledge & experience. SO no problem with that.
Also, post a wanted ad in our classifieds section. Will help.
Regards.
