goldyrathore
Hi All,
While searching for a locally available stuff to coat foam surrounds (for long life and also making it air tight), I came across this fabric glue.
The following are some of the characteristics of the glue:-
1) Seals foam surrounds.
2) Adds a light glossy sheen to new surrounds.
3) Gives a "wet-look".
4) Is white in color and becomes transparent on drying.
5) Is rubbery after drying.
6) Does not crack on bending.
Is it the same stuff that is used elsewhere too for the same job, but with a different name, for e.g.foam guard etc?
Thanks,
Goldy
Thanks,
Goldy
