Good quality power strip preferably with copper sockets
whiskymusic
Kolkata
As title says, I'm looking for good quality power strip preferably with copper wires and sockets as my existing ones with aluminium sockets get corroded over time.
I talked to local electrician to build a custom one for us but he couldn't find foreign tops to insert US/EU plugs.
Any Suggestion?
One of my friend imported sockets from Qatar as he couldn't find any descent Make In India stuff over here. The local stuff looses its springy action. Or try to get something from EU. Brass is a good material for plugs & sockets while copper is meant for making wires. Just avoid those "universal traveler" adaptors / convertors
Any Suggestion?
These (Gongniu/Bull) are good quality power extension boards. You get these in different wire lengths, and versions with or without switches for each plug.
I’ve been happy with Belkin. They are priced around 1000-2000 Rs on Amazon depending on how many sockets you need. Good contacts and trouble-free. IDK if they are made of copper or Aluminium inside, but haven’t corroded and after five years the sockets feel as good as new, retaining their springy action. They have surge protection built in. Also well-built - can take a few knocks without even surface scratch. I found them better than the MX strips I used earlier.
Ditto experience with Belkin and MX. The cable quality of the belkin is also better than the MX ones
Can't go wrong with the Sound Foundations Barracuda. Perfect fit for all kinds of plugs with zero play.
I am using Belkin and Havells powerstrips, both have surge protection. Belkin is for my 2 NAS + Ethernet switch connected to UPS for power. Havells we are usually for other "casual" stuff like phone charger + laptop adaptors etc. Zero issues till date.
