Greetings!!
R128
Manjeri, Kerala
Hello all. This is Rajeev from Manjeri, Kerala. I have been wanting to buy an LED projector for some time now, but have not been able to because of the size of my wallet and I just found out this website. I hope to get some good advice from people in here. :)
Rajeev.
Hi Rajeev,
Welcome to our forum:).Sure you'll find what you're looking for here.
Meanwhile I think you're looking for LCD projectors & not LED projectors.
Currently LED projectors are only a handful and outrageously priced.
Some of the best projector are DLP based and this tech can be found in most projectors.
Can you be more specific with your requirements, like Source (DVD, HTPC,Bluray etc). Projection size required, room size,Screen or wall projection etc.
Just start here Home Theatre Projectors & Screens. I'm sure you'll find it interesting.
Samuel
Thank you. Sam, I did mean LED projector, specifically the LG HS201. I checked it on LG India website and it was quoted as 50,000 (and it sells for 500 USD on Amazon) . I have not called up a dealer yet.
I plan to initially connect it to my PC and later set it up in the living room.
The living room size is 11.5x 20 feet has and has 3 windows (see attachment).
The most important thing is I need to save some to make this a reality :)
