aaryan.varun
Code:
General
Unique ID : 189757810621315704178530733346583168323 (0x8EC2066426DD58609D071AEDB0134543)
Complete name : F:\HP\Transformers.Revenge.of.the.Fallen.2009.BluRay.1080p.x264-10bit.DTS-HDT\Transformers.Revenge.of.the.Fallen.2009.BluRay.1080p.x264-10bit.DTS-HDT.mkv
Format : Matroska
Format version : Version 2
File size : 15.7 GiB
Duration : 2h 29mn
Overall bit rate : 15.0 Mbps
Encoded date : UTC 2012-12-27 00:43:30
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 11 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 29mn
Bit rate : 13.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.265
Stream size : 13.8 GiB (88%)
Title : tanda@HDTime
Writing library : x264 core 129 r2230+696+35 805d074 tMod [10-bit@4:2:0 X86_64]
Encoding settings : cabac=1 / ref=12 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=1.10:0.05 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=3 / bframes=12 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=21.0000 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.22 / aq=2:0.85
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 29mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.58 GiB (10%)
Language : English
Default : Yes
Forced : No
i downloaded this movie.
high video bitrates. it plays fine on my laptop but when i try to play this file using my blu ray play, i can see severe pixalation and its sort of distorted.
has anybody ever faced a similar problem?
help would be appreciated
