Headphone Plug Adapter Extension
Doomster69
Gurgaon
Hi all,
I bought a balanced cable from Hifiman (https://www.hifiman.com/products/detail/180) for Sundaras. It works fine with most amps and didnt face any issue. Planning to use this with a Schiit Asgard 3. However, Schiit website mentions not using TRRS plugs and they sell an adapter for TRRS plugs. https://www.schiit.com/trrs
Wondering if i can use the balanced cable as is?
Also iv been using the TRRS cable with TRS 6.5mm adapter on the headamp currently. No SQ or gain related troubles so far, but wondering if this is bad for the amp? My guess is it will have grounding issues?
Would it be ok to use something like this?
Thanks!
