S Sopra Member Joined Jan 3, 2021 Messages 97 Points 18 Location India Aug 28, 2024 #1 i have a HD30..connected using RCA..want to change to a XLR- does it make that much of a difference?
AP@1992 Active Member Joined Nov 6, 2023 Messages 197 Points 43 Location Mumbai Aug 29, 2024 #2 Sopra said: i have a HD30..connected using RCA..want to change to a XLR- does it make that much of a difference? Click to expand... in the following cases, you "may" see some benefits, gravity of which will depend on your system, choice of songs and for course your ears: a) if the device is inherently balanced b) if you use for longer runs c) if the DAC is surrounded by many equipment and your wires arent neatly arranged
S Sopra Member Joined Jan 3, 2021 Messages 97 Points 18 Location India Aug 29, 2024 #3 thank you. My understanding was that XLR cables are able to deal with noise better than RCA but I guess this would only apply like you said if there are wires around and perhaps some interference.
