Hello
Hi, I am a newbie looking to setup a small home theatre. The amount of choices is truly overwhelming! Very exciting journey indeed!
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
