Hello_ I need help on Yamaha RX-V375
mhsramu
Hi there, good day to all!
I just got my V375 from US, AMAZON.COM.
I am just a beginner in Home Theatre scene.
My unit is not powering up, I wonder this system voltage rating is 120/220V, auto switchable. (I refered spec-sheet and internet sources)
anybody knows what the problem is?
thanks.
Ramu
When I see the manual, It was not auto votage 110~220.
You are to select the votage 110 or 220.
If you connect 220v in the setting of 110V.
I am sure that it was fused.........
Open the cabinet and see the power inlet and change the fuse.
Good luck! ;)
Good luck! ;)
thanks mr. tiger.
this unit says 120 ~ 250W, but there is no switch to select the voltage. hoping it will work in India, so I had connected, then it didn't powered up, but my spike buster fuse gone. replated, but still not powering up. thanks a lot for the response... I shall check for the fuse inside.
thanks
From your description, it is a 120V device. Do not connect it to 220V. Get a good quality step down transformer.
The manual clearly states that the selector switch should be set to 220 V before connecting. (refre connecting the power cable - Page 27 as per online manual) The fact that the Fuse blew indicates that you have not done so. Do not try to connect again unless you have located the selector switch and set it to 220 V.
thanks a lot for the reply.
this unit didn't had any selector switch. so my mistake.
still not learned after couple of problems encountered.
does it cost me a bomb to get it repaired, any ideas:
thanks
I know you are worried about power supply.
on other note -
how was the delivery experience of 375 from amazon.
any issue with custom, post etc.....
X75 series is on high discount, your input will help other forum member.
on other note -
+1 to this..will u please share u r exp in importing this from amazon !!!
