sushantsah
Expert advise needed, as every blog says something diff.
I have a small dedicated room 10 x 16 and wants to set a small yet good quality hometheater, my existing is 40 inch sony bravia; with 5 speakers and ps3.
I am planning to upgrade to a decent hometheater for HD movies, gaming, youtube video over wifi, keeping in mind small size of room.
Shall i use 40 inch sony or buy projector.
Also suggest av, speakers, active woofer
My budget is between 50 to 100K (Inclusive of Projector), if i can use sony 40inch, then for av, speaker and woofer 50K
Decoration, wall, light panels, acoustic little treatment i will get it done separately
Also i live in a small city where yamaha, or other good brands showroom are not there, so whats best buy online or from delhi (300 kms from my location), what about service support ???
thanks a ton in advance, i plan to install this in 15 days...
