Lalrinzuala
Hi, everyone. I am planning to build a bookshelf speaker. If there is a similar thread alreday started i’d like to appologise beforehand. But my query, requirement and budget may differ.
So my existing system Is
Amplifier - 1. Marantz sr5013
2. Pionner sa 706
3. Old philips amp.
so any three of these maybe used to drive the speaker.
Budget - 20k -25 k ( excluding the carpentry work)
My first query
1. Full range or 2 way system.
I prefer a softer sounding system with a soft thumping lows.
2.Will i require a seperate sub woofer if i use aFR system ( already owned a budget boston audio sub)
Willing to build a new sub.- seperate budget
2. Pionner sa 706
3. Old philips amp.
My first query
