Help me find my setup
akshayraos
I am setting up new home and I am looking for a home theatre system for the living room.
For now my budget is about 30-50k INR. So I am not sure if I should but off the shelf 5.1 or 3.1 set up or but the receiver and set up everything separately.
All the 5.1 HT systems I see are with soundbars. Are they any good? Any option that has proper speakers. Any such off the shelf 3.1 system that can then be upgraded to 5.1 if required?
If I go the other route, what are some budget-friendly options for receiver/sub/LR speakers/Centre speaker? Cna it be done in a budget and upgraded later?
I also would like to be aesthetic. Something I can fit into a TV wall. any concealed speaker options?
I know these are a lot of questions. ASking them because I am not able to decide which way I should go. Thanks in advance.
