Help me out
jice505
Chennai
Hi all ,
I have LG 42LW5700 tv in my home.. I want my TV audio output in my onkyo 3500 .. I wanna connect it through HDMI or composite .. Please help me out ..
Thanks in advance
Unless you TV has an Audio out, this is not possible.
If you have a set top box, connect that to the Onkyo, and the Onkyo to the TV,. If you have a HD STB, that will have an HDMI. Elase you have to use composite all the way.
Hi all ,
Thanks in advance
connect the HMDI that has ARC (search the back side.. ARC is marked in the HDMI point) in your TV to the onkyo AVR. i think the onkyo supports ARC
Hi all ,
Thanks in advance
I was unable to find any Audio Return Channel (ARC) support in the specs of the tv, so I presume it does not support ARC. If that is the case then your only option is to run an optical cable from TV to 3500:
TV optical out > onkyo HT-S3500 optical in : Optical cable
If your tv does support ARC, then you can use HDMI:
TV > onkyo HT-S3500 : HDMI cable
ensure you enable ARC on the tv and the HT.
