Help needed for buying an Home theatre - budget around 40k to 50k
pratik88
mumbai
Hi All,
I am from Mumbai
Just like others I am also planning to buy an decent home theater.
My Budget is around 40-50k.
My requirements r
- wanted a system basically for movies and cricket as i have a projector installed
- area is round about 500 sq.ft. i.e. about 25' x 20' (approx)
- It should be capable to play songs such as trance, rock, pop.
- i love base so it should have the bang sound
- i would even be using it to play games on ps3
Gurus pls help me out as i am very new to this concept, and getting really confused wat to buy n wat to not
(ref- would like to buy small sized speaker i.e. no towers )
regards
pratik :cheers:
Hi All,
I am from Mumbai
My requirements r
regards
pratik :cheers:
search for my thread with similar topic and u will find a lot ideas how to go about it. At the sametime there are other threads too. njoi
thank you for the reply midnight :-)
can you tell me
how much rmp watts do we need for 500 sq.ft. area?
500 sq.ft is pretty big , you can easily drive BIG floorstanding speakers.... I'd suggest you start auditioning a pair of FS speakers and an AVR or amp to drive them later add the rest of components to build a complete 5.1 setup.
