Help needed in setting up a HTPC
vickysami
Hi All,
I been reading this forum for a while but still have some concerns about how to setup the HTPC, and I need help in setting up a HTPC with reusing my existing setup.
If I cant reuse please let me know the alternatives.
Total Investment - 10,000/- to 11,000/-
Motherboard, Processor, Ram
Requirements:
I want to connect HDMI from PC to TV(LG 42") and Optical from PC to receiver(Onkyo 7.1 HTS 5100)
Dont want to buy additional Video and audio cards.
Play HD Movies - 1080P (Bluray rip movies)
Games like - Farcry, Mostwanted, Max Payne (Not toooo high end games)
My current setup:
Motherboard - M2NPVM - I need to buy new one as current one does not have HDMI. Need to know which i can buy with my budget.
Processor - AMD 2 Athlon 3800 64 ( can i reuse with new motherboard i buy ?)
Ram - DDr2 1 GB ( can i reuse ?)
Power Supply - notsure how it is.
waiting for response. :)
Vikram
Hi All,
Requirements:
My current setup:
Vikram
HTPC solution - would not work with games
if you want to watch movies you should buy a good video card
this solution does not meet your constraints, but for hTPC is a cheap and sensible way--
really low cost would be -- add a gt9400w/hdmi for about 2.5k.. add another 2 GB of RAM for another 2+k, add a bd drive for about 7k.. you're done..
i'm not much of a gamer, but a 5670 for about 6300 would take care of most things before you cpu becomes a bottle neck.
i am assuming your athlon is socket 939 and not am2. AM2 would allow a upgrade path.. 939 is a deadend..
PSU- depends on the original.. cannot harm to buy a better psu..
Meeting your requirements (again htpc focussed)
e5300 - 2900
g41 mB- 3400/-
http://www.theitwares.com/gigabyte-gag41mes2h-intel-hdmi-micro-intel-motherboard-p-468.html
2gb ram - 2800/-
=8100/-
better
e5400 - 3k
g45mb- 6k
http://www.theitwares.com/gigabyte-gaeg45mud2h-intel-micro-motherboard-p-323.html
2 gb ram - 2800
about 12k.
no intregated graphics will allow any high quality game play..
cheers
