Help needed to setup Wifi
sunilkm
I am using BSNL broadband internet connection at home ( BSNL modem is UTStarcom UT300R2U ADSL2+).
I need to make Wifi access to connect a netbook and galaxy tab2.
Ordered Netgear JNR1010 N150 Wireless Router and will be getting it today. I need some help to connect this to BSNL modem to Netgear and configure for the access.
I should have the internet connection to the Desktop by Ethernet cable as it is now.
Could not find a step by step procedure to configure. If someone can post or point to the steps it would be really great.
Was going through some posts in other forums and confused.
Currently the BSNL modem is setup in PPPoE mode. Do I need to change this this to "Bridged Mode" to connect the wireless router to it?
(OR) Should I keep the BSNL modem in PPPoE mode and connect wifi router?
Some help is needed on this setup...
These days router have fairly easy setup. Just keep the modem in pppoe mode only and plug the ethernet cable in the "wlan" port on the router. If everything goes well the router would automatically pickup the settings and configure for use.
One you can connect to the internet you can set wpa2 password on wifi for security issues.
