arnprasad
Hi all,
I have an Exide inverter/UPS setup at ground floor. Its a 1050VA @ 85% efficiency..so practically around 700 watts of usable power. I have my entire plug points/Switches split into UPS and non UPS. All heavy duty ones like fridge/washing machine..,..etc are in non UPS setup.
I have bought a second UPS and battery and having it installed in first floor. Now the UPS has two modes..in Luminous the first mode is called ECO which is basically bypassing UPS and hence in case of a power failure it takes around second for UPS to start functioning and hence not suitable for office working/desktops. The second mode is the UPS mode where power always goes via the inverter and in case of mains failure, we don't notice a difference.
Now my electrician is telling me that there is no need to split all my first floor plugs and switches into UPS and non UPS. He says even if UPS is rated for say 700 watts as long as we have mains power - even if I use heavy duty appliances like microwave and convection oven - it shouldn't matter and they will work. Only when the mains is off, it will show as overload and shut off. I don't think this is how inverters work, particularly in UPS mode. Please advice. I need this clarification since he is installed it yesterday and he is still around today and if I cannot use my ovens when the mains are on - I need him to make 5A/15A sockets as non UPS ones like in ground floor.
Below are the questions again:
(a) in "Eco" mode on my inverter of say capacity of 700W - Can I run appliances totaling say 2000 W when the mains are on? I believe the answer is yes, because I did have all the lights and fans and both my ovens on yesterday and they all worked. However this mode is a problem for me because there are desktops and routers which need uninterrupted supply...hence point 2 below
(b) To suit the needs of routers and computers - if I have the inverter in UPS mode - even when mains are on - Can I run appliances totaling more than 700 watts?
I tried googling - but framing this question is very difficult and the only answers I got was differences between UPS and ECO modes.
