benadryl cabbagepatch
Hello everyone, new user here
Please excuse my beginner knowledge in this zone.
What began as upgrading a 23 year-old set of JVC MX-S300 stereo into a Bluetooth system turned into a desire to build my own set of speakers. I am still surprised with this old system sounding just as amazing as it did years ago. Soon I began reading up on drivers types, driver parameters, crossovers, cabinet design, etc... and the more I read, the more confused I got .
Introduction aside, I obtained a pair of 'woofers' and tweeters manufactured by Peerless Fabrikkerne. (got it via eightaudio.in)
Primary aim of this project is to build a budget speaker system that sounds decent at medium hearing levels (very occasionally boost the volume). I plan to use it with my desktop, and at times in the living room in case of small/quiet parties. Secondary aim is to make the speaker have a small footprint/unobtrusive if possible. (like the mini-tower or tower designs). I don't mind a bit of challenge in building my first speaker.
Basically, I want to design a 2 way stereo system using a TDA7492P 25W+25W board with Bluetooth receiver, using the combination below -
Peerless Fabrikkerne 4" KO100 WFR (8 ohms)
Peerless Fabrikkerne 1/2" Polycarbonate Tweeter DW 69 (8 ohms)
with a crossover at 4000 Hz.
Found two ways of choosing the 'appropriate' enclosure : looking at EBP or Qts. I used the values from the drivers manual and obtained an EBP of 150, which implies ported. But a Qts of 0.531 says sealed. Ofcourse, these rules are non-binding apparently, but given how notorious speaker building is known for settling for the right compromises, I don't know how to proceed. I referred diyaudioandvideo's online calculators as well.
Regarding woofer parameters, the specifications detail a 4 ohm driver, I assumed a similar ratio to be carried over to the 8 ohm, thus the new dc resistance is put as 6.4 ohm. I am ball-parking with voice coil inductance value. Calculated Xmax comes around 0.75mm, although I must say that it seems suspicious to me as I tested the speakers bare for an hour or so at medium-high listening levels in a small room, and the cones seemed to bounce a lot more than that visually.
Another problem I face is the apparent discrepancies in driver parameters. I am attaching the spec sheets of the drivers I found online.
Below is a website information regarding the speaker. (same details on eightaudio.in as well)
Peerless Fabrikkerne (I) Ltd - KO100 - 4" Coated Paper Cone Woofer
I don't understand how Vas jumped from 4.1 litres to 11.3 litres.
Any guidance from people who have used these?
