Help Required :Bought Pioneer HTP071@16500
kghanate
Ahmedabad
HI,
I recently purchased a Pioneer HTP 071 from reliance Digital - Ahmedabad @ Rs.16500.
The Configuration I have made is as follows:
D2h HD ---> HDMI --->Pioneer
Asus O pLay Mini ---> HDMI --->Pioneer
Pioneer--->HDMI ---> Samsung 32 inch LED TV.
Now the major issue I am facing are two:
1. Whenever I am playing movie or changing movie from asus media player, the screen suddenly goes blank for about 1-2 seconds with no signal and when it restarts shows the 1080@50Hz or 60 Hz. I had tried replacing hdmi cable of asus media player with d2h hd box then it works fine.Even i bought new blue rigger hdmi cable then also its same with media player
Is this a TV Issue or Pioneer Issue or media player Issue. Needless to say I need to fix it.
2. Earlier i was having panasonic sc vk 30 Music System. The speakers SB VK30 are still in good condition. The back side of speaker says its 6 ohms & 1300W Input (Music)
What if i replace the panasonic speakers with front speakers of Pioneer HTP 071(AVR -VSX 321 kp) and change the speaker setup of front as large speakers. Will this create any load on receiver or quality.
Guys do let me know how I can fix the above issues.
Much appreciated.
Kiran Ghanate
Hi, I also like to purchase this Pioneer HTP-071 as my budget is very tight. Are you satisfied with this Home theater? Please narrate your experience after use of it specially pros and cons. I am having D2H HD set top box and at present they are providing dolby sound through hdmi. What is the surround sound quality from its speaker?
