manindra.mukherjee
I am having a Yamaha HTR 2064 (part of Yamaha YHT 196 HTiB) with the below specs
Amplifier Section Channel 5.1
Rated Output Power (1kHz, 1ch driven) 100W (6ohms, 0.9% THD)
Dynamic Power per Channel (8/6/4/2 ohms) -/130/160/180W
Yamaha Speaker Specs
Driver 7cm full-range cone
Nominal Input Power 30 W
Maximum Input Power 100 W
Sensitivity 83 dB/2.83 V/1 m
I am planning to upgrade the stock speakers with Sonodyne Genie 1 for Front and Surround and Genie V2 for Center which I auditioned and found to be good (with Denon AV available at showroom)
Specs for the speaker are:
Front and Surround Speakers (Genie 1)
CONTINUOUS POWER (RMS): 60 W
SENSITIVITY (1W/ 1M) : 87 dB
FREQ. RESPONSE (+3 dB) : 130 Hz ~ 20 kHz
NOMINAL IMPEDANCE : 8 Ohm
Center Speaker (Genie 2 V2)
CONTINUOUS POWER (RMS) 85 W
SENSITIVITY(1W/ 1M) :89 dB
FREQ. RESP. (+3 dB) :110 Hz ~ 20 kHz
NOMINAL IMPEDANCE :8 Ohm
I have the below doubts and seek advise on the same
1. Will this combination deliver a better performance....i.e. Will the amp be able to drive the new speakers. I have a separate active sub woofer and have disconnected the stock passive sub which came in the box.
2. Is this worth an upgrade. Sounded pretty good at audition though better than my HtIB.
3. Can I just upgrade the front 2 speakers and leave out the center and the surround. Will that have a non uniform sound effect
