Help required to select a Power amplifier
Desibell
Pune
Hello friends,
I am looking for power amplifier recommendations to go with Luxman sl120 pre and Dynaudio Excite 34 towers.
Any suggestions please? Thanks in advance.
Desi-bells
Hello friends,
Desi-bells
You have a luxman pre
And you haven't considered the luxman power
C'mon
That's the first place you should look
Shitij
From.designer audio is the official luxman importer for.india
Please Google
Designer audio mumbai
Rs 14 lacs Is what they are quoting for Luxman. I have a budget constraint. Anything is the range of 1 to 1.5 lacs works well with me.
Thanks again.
The luxman
Integrated amps are really good too
Maybe you could consider them
They are not as expensive as the power amp
Maybe you could even trade in your pre and go minimilastic
However if you need a power amp on a budget
Something that would do justice to the rest of your equipment
You could look at
Posibly considering pre owned equipment
Possibly something like an accuphase power amp
Which would be a nice choice
A Naim power would also be nice ( however getting those pre owned may not be easy )
Mind you
At the risk on being scoffed at
The newer NAD power amps are really nice too
( You can't really club the newer NAD signatures with the era old 320's etc )
Though I do understand all these options are gonna be 2.5L plus
So might not work for you
P.S I do think though presonally you should try and control your upgrade itch temporarily and save up for something better later rather than scratching that itch right now
Thank you for all your valuable inputs. Some changes at my work have made suffer my decision to upgrade. . I will definitely consider your suggestions when the time comes around.
