Hi y'all,
I’m new to the audio world and looking for advice on buying a 5.1 surround sound system for my room. It’ll be primarily used with my PC, and down the line, I plan to hook it up to a projector eventually.
For now, my budget is around 25-30K (but I can stretch it a bit if there's something that's really bang-for-the-buck).
I’ve been reading around and some people suggested that I could start with a stereo setup and then add the center/rear speakers later. I’m open to this approach, but I’m not sure how to look for compatible components.
Any recommendations or advice on what systems/speakers to look for, compatibility, or even brands would be really appreciated!
Thanks in advance for the help!
