Help Subwoofer selection for PSB Image b6
desiguyinus
India
Hi All,
Picked up a Denon AVR 2113 and a Pair of PSB Image B6 speakers.:yahoo: Now hunting for a good sub woofer and center speaker. Thinking of buying Image C5 for center and may be used sub ??.
I have couple of queries.
1) Can Denon drive the B6 to their capacity ? ( amp required? )
2) Which sub will sound better with the Image b6 and also can you suggest surround speakers for 5.1 setup ?
The room is 15X12. Usage will be 50/50 Music, movies. More into western classical , soft rock , pop kind of music.
thanks for your help
Thanks for the reply.
Then I would probably pick up Image C5 for center and B5 for the surround. Any suggestion on the sub?
