Help to choose dolby atmos speaker
I have denon x3300 5.1 setup with polk speakers . Planning to add dolby atmos speaker , Can get speaker from US. Will something like this is enough ? https://www.amazon.com/gp/product/B00KSLX706/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
If not please suggest some speakers around $50 . Thanks.
There are lot of speakers in the market available for Dolby Atmos purpose and specific placement.....
https://www.amazon.in/Onkyo-SKH-410-Atmos-Enabled-Speaker-System/dp/B00O8LANJA
For the AVR you have, you need something which is at least 100watts RMS.....so look out for available options.....
I generally don't consider the bounce off atmos speaker as a real atmos speakers. The effectiveness can vary very much depends on so many other factors. I prefer the sound direction of atmos speakers to be spreading rather than directional.
Even though it's costly. This might suit you, Swivel is must since you can adjust according to your seating position and don't need to change the mounting everytime.
https://www.amazon.com/Polk-Audio-Performance-Vanishing-Ceiling/dp/B01BV5RBXQ
But does the mount fix into the dv32??... I don't think the dv32 has mount threads.. so is the speaker just hanging on the mount??
