Help with speakers with Denon 1513
sanjay1970
india
have been around in the forum just going through the post trying to improve and gain some knowledge of hifi but till today have not bought anything for the audio.
A friend of mine has given me a denon 1513 and now i have to build my HT around it
have a 12 X16 room with a 50 inch plasma to it
preference would be 50% music and 50% movies
Do have have a huge budget to start off but going through the forum have come to conclusion that building the system would be great
Did think of the Wharfedale Moviestar MS-100 HCP but do not have that budget immediately
Can i think of the pioneer SP-PK21BS as the fronts for the time being which can at a later stage become the surrounds at a later stage
what CS can i think of for that is going to remain part of the HT
My budget is around 20 to 25K for the time being and looking at around 50 K when the time comes
If not can the esteemed members suggest a front and centre speakers for the Denon with a budget of 20k
I know i need to audition and buy what i like as far as music goes but need to know what would be good before i make a decision
thanks guys
sanjay
if you intend to build your system step by step then it's a good idea...if you have a budget of 20-25K then you should invest it in 2 bookshelves and a centre, although you may have to strecth a bit to accomodate these...good BS will cost you anywhere around 18-25K + 10-15K for a good centre channel.
If you want a system which serves purpose for music+movies then do not go for satellites, MS100HCP is a satellites based package. wharfdale diamond series is known to be good for music+ movies, you have other brands like Sonodyne (VFM), Polk audio, Boston Acoustics etc.
