Hi all..building my dedicated home theatre
shelley
Trivandrum
Hi all,
I am Mr. Shelley from Trivandrum, a software professional. I am building a dedicated home theatre on the 3rd floor of my house.
Civil works status:
Concreting over. Electrician has installed the pipes (20mm) for speaker cables, power modular boxes of legrand etc..Probably, Plastering will start tommorrow..not sure because of rain.
Room Size: 24' length , 14' width, 9.5' height.
Planning a 7.1 HT.
I find this forum extremely helpful and with tons of valid info and experienced members. I request help from all of you regarding my AV equipments, Accoustics etc...
I have no specific budget..Will buy components individually and it will be spread over a few months...Currently doing research on various components of a HT setup. First thing I will be planning is accoustics...Lot of people have recommended glass wool as sound absorbing materials.but I am planning to use poly fibre as it is less hazardous to health and durable.
How many rows of seating?
For acoustics, use absorbers to cover as much of the front wall as possible and at least the middle third to half of the back wall.
Problems in the bass range can be dealt with using careful placement of subwoofer(s) and L/C/R speakers.
Currently planning for 2 seats...Accoustics seems to be the major headache...I am confused as to go for DIY treatment or accoustic panels like anutone, armstrong etc...
as you dont have budget problem..
go for sim2/runco projectors...
for audio
get separate pre processor from nad or anthem
or onkyo...people dont want to consider it is of same leauge though...
get mono power amps for each channnel...from quad or alike..if you like tubes..can try conrad johnson..
get panamax power supply
stwerat/black diamond...screens
speakers choice personal..
Just to clarify, 2 rows of seating or only 2 seats (2-person home theatre)?
Acoustics shouldn't be a major headache. The first thing you can do to get smoother frequency response (fewer peaks & dips) is speaker/subwoofer placement.
If you blow across the opening of an empty Coke bottle, you can get that small chamber to resonate (make that booooooooh sound). If you enlarge that Coke bottle to the size of your 24x14 room, that large chamber will still resonate (at different frequencies, of course).
The 14 foot width of your room will cause resonances (room modes) at roughly 40Hz, 80Hz, 120Hz, 160Hz, 200Hz etc. Which means that listeners will hear loud peaks and quiet nulls at those frequencies, depending on where they are sitting. You can cancel the 40Hz mode by placing a subwoofer at the midpoint of room width. You can cancel the 40Hz mode AND the 80Hz mode by placing a pair of subs 4.5 feet away from the side walls. The next few modes can be cancelled by placing your L/R speakers 28 inches away from the side walls. The cancellation will improve the frequency response across the room (all seats, all listeners).
With major problems below 200Hz addressed using speaker/subwoofer placement, problems above that frequency can be addressed using treatments. This is helpful, because trying to treat bass problems requires treatments that can be up to several feet thick, which is impractical. Instead, more practical to use placement (doesn't cost anything to move speakers and subs around).
To absorb frequencies above 200Hz, the treatments can be thinner than bass traps. Somewhere between 6-8 inches thick would be effective. However, this is one of the very few things in acoustics where you can get something for nothing. Rather than building an 8-inch thick absorber, you can use a 4-inch absorber and place it 4 inches from the wall. The 4-inch air gap will make the 4-inch absorber almost as effective as an 8-inch absorber (but using only half the material).
I'm not familiar with Anutone or Armstrong, just get insulation material (fiberglass, rockwool, etc) that is around 2.5 to 3.0 pfc (pounds per cubic foot). If you can find that locally, you'll save a lot of money by going the DIY route. Build thin wooden frames that are 4 inches deep, place the material inside the frame and wrap the whole thing in a breathable cloth (speaker grill cloth or even just plain old burlap).
@sdurani Thank you !
I meant 2 rows of seats..
Currently reading "Master Handbook Of Acoustics"..to get better idea of accoustics..:)
Glasswool and rockwool seems to be hazardous to health and can go powdery in the long run creating more problems in future. I am planning for polyfills.
Another issue is that if we place insulation materials along the entire room it will create a dead room. So I am planning for placing absorbers only as needed + diffusers +brass traps...Currently reading to get better idea of accoustics..
'Master Handbook of Acoustics' is a good read, tilted more towards recording studios and control rooms. But for designing a recreational listening space at home, you should read 'Sound Reproduction' by Floyd Toole.
Got a copy of "Complete-Guide-to-Highend-Audio"...Seems like a nice book..Will try to purchase 'Sound Reproduction' by Floyd Toole..
Welcome to the world of Home Theater.
In case of Glass wool the adverse factors of hazardous, health or durability is surely not a issue if handled well.
All the best.
V.
If you are looking for a top of the line 3chip DLP projector(Runco ls10i) which I am selling because of room size issues then please do get in touch with me.
