Hi all,
RayD
Suffolk
I recently purchased a Garrard SP 25 MK IV to restore and think that the micro switch has failed in some way. Does anyone know how to test them or any advise. The motor has stopped ???
Welcome!
Maybe you should ask your query in the Phono/Turntable section to get any help.
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
