If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
If budget is a constraint and yet you want to get a good system, you should then consider the preowned market (OLX / Classifieds) where you can get something really good for much lesser.
