dkadavarath
Hi all, New member here. I was looking into buying an HTR-3072. I had an old Panasonic SC-DK20 Home theatre. The main unit broke, but the speakers are still working fine. I was thinking of coupling the Receiver with the said speakers. Except the sub woofer, all speakers have 6 or 8 impedance. Woofer is 4 Ohms though and I was wondering if there's any way to match the impedances. I'll providing info on all the speakers below. These speakers were able to fill my room reasonably well, paired with it's original unit at average volumes when it was working. I'm looking at this new receiver for getting more fidelity and more connectivity options. I'm a bit cash strapped now, but eventually, I'm planning to get better speakers that will suit this new unit better.
Front Speakers (2 way speakers)
12 cm cone woofer and 6 cm cone tweeter
6 ohm impedance
80 W input power (Music)
Surround speakers (1 way 1 speaker closed)
8 cm cone full range
8 ohm impedance
70 W input power (Music)
Center speaker (2 way 3 speaker bass-reflex)
8 cm cone woofer x 2 and 6 cm cone tweeter
8 ohm impedance
160 W input power (Music)
Subwoofer (1 way bass-reflex)
17 cm cone woofer
4 ohm impedance
340 W input power (Music) 170 W (DIN)
I'll watch a lot of movies on this, but most of the time, it'd be working with TV audio as the TV I'm using has very bad speakers.
I'm located in Thrissur, Kerala.
I'm open to suggestion of a better way to go for this. My budget is around 25K and this receiver is right on the border. I looked into the YHT 1840 which comes with it's own speakers, but I didnt want another set of speakers and it's way too high for my budget. I'm also curious to know what's different about 1840 and 3072. Are their receiver units the same? Thanks in advance.
6 ohm impedance
8 ohm impedance
8 ohm impedance
17 cm cone woofer
4 ohm impedance
