Hi I am beginner in HT
Beginner_N
Pune
Hello all,
I been reading reviews and information on this forum for longtime.
I am really thankful for all the info i have received so far.
I am looking for 2 thinks 1. Phono preamp for turntable and 2. DIY center channel speaker details or best center channel speaker.
I have Yamaha 675 receiver 4 sony old speakers and Astonia active sub DF-10.
Thanks and Regards,
Nishant
Welcome to HFV.....
I am sure you will enjoy your experience here, there are a lot of experience members even professionals who will help you out.
If you check out the DIY section of this site, you will get some ideas about centre channel speaker..
Remember, the centre channel speaker and the subwoofer are the most important components in a Home Theatre setup and so would recommend that you either get a good centre speaker based on your budget....check HiFi Mart for some good options...Wharfedale / Boston Acoustics etc are good value for money...
In terms of Phono preamp for turntable, there is a dedicated section on HFV which can give a direction...there are ofcourse quite a few pre amps available in the market. SInce you are Mumbai based, there are ample places you can go and checkout.....Telome Audio, Norge, MZ Audio, Sonodyne, etc. etc.
