hi, new here, want help
gudu
Bangalore, India
Friends,
I had one philips micro system which does not play the newer types of cds that is the mp3.
So I had to go for a music system.
Dealer suggested I better go for bluray dvd system with home theater. I ask it play music, he told yes and I bought it.
its this one..
Now problem is, it not suitable for listening to music all seven speakers will be blaring sound like anything.
I want a deck.
I did my research and I found this one, but not impressed with it.
This one costs 24k
Can you suggest me deck within 30 k for only music purposes.
Let be clear with your choice, you want to hear music but through all 7 speaker? Is this right? Now tell me about the deck you choose, the model number. Are those 7 speaker are made by same company like the deck? Is it a Home Theaters setup?
Welcome to HFV. Stereo system should be used for music listening. Bluray can be enjoyable for movies.
Friends,
its this one..
I want a deck.
This one costs 24k
Could you share the Music system which you have bought, Your issues is "Music from all 7 speakers are not clean" and you like to hear only in Stereo set-up or like to add something to the current system so that the seven speaker sounds fair?
Sorry for silly questions, but your requirement is unclear
Hi all,
I was looking for deck, but the dealer sold me this blu ray home theater system which is good only for viewing movies and not for enjoying music
the model is: Sony BDV-E290
Now I want to buy one good music system.
I saw this deck: Sony MHC-GZR888DA, but I am not pleased with the quality of the sound delivered.
So can you please suggest me one good music system within 30K?
If you suggest assembled music system, I would assemble amplifier, player speakers, I would do it in that order.
Thanks for the suggestion for onkyo mini hifi series CS-V 645.
Packed with features, but still am looking for huge sound.
Will go for assembled one, if anyone would suggest.
Player, amplifier, speakers.
Specifications if anyone is willing to tell, which player suit for which amp, and suitable speakers. Would be very thankful.
whats your source...cds or stored files...
you can have a cd player or a usb DAC depending upon that.
for amp sonodyne and norge are very good budget products.
for speakers wharfe 9/10 sonodyne sonus..etc are good..in budget.there are many speakers..can try used gears also..much amount can be saved..
