I have been reading these forums for quite some time on and off. Looking forward for more.
I am sure you found your experience here very enriching and enjoyable by visiting the countless posts which is based on direct experience, technical knowledge and honest feedback.
If the post / response has helped in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member) and also motivates to contribute more.
