Hifi Stereo System!!!
davinci
Chennai
Am planning to buy a new stereo system, which should have MP3 and CD
playback with USB support for my room size of 11 x 16. My budget is around 35 - 40 K.
So far i have chosen the following,
1) Denon M39 MiniHifi
2) Marantz M-CR503
Speaker - Swans D1080MKII
As i don't have much experience in Hifi systems,please share your opinion and also suggest for better rigs.....
check hifimmart sale section a marantz cd player and int amp is sold very cheap...
Marantz PM5004 + Marantz CD5004 Stereo System
35k only......
go separate way(not super seaparate thats costly)...I personally dont like the mini hi fi combo systems....
a cd player
a int amp
a pair of good bookshelves...try wharfe diamind 10 series..or sonodyne avant series...
so if yoy buy the above offer consider additional 15k fro a pair of bookshelves..
total 50k.......but no lookback..a solid system....otherwise witha 35k set up you will surly feel the upgrade itch...
I too considered that, the only drawback is CD5004 doesn't have an USB input
to playback drives:sad:....otherwise its a great deal. if i need to go for a better one, i can extend my budget to 10K+......
After several research, i have decided to go with Wharefadle diamond 10.1
Now i need to decide on AMP either SIA320 or PM5004, as far i know, the Maranatz will be slightly underpower, but at the same time i dont want to compromise the quality.So please share ur comments..
yes perfectly said...marantz is much better...
but at the same time if possible demo to like the audio signature...
contact elangoas he is using cia with wharf..........
Hi Elango....
Hope you would share your experience with SIA320 & Diamond 10.1.
Tommorow am planning for an audition with Marantz!!!!!
So It would be helpful to share your comment on Sonodyne AMP...
Hi Elango....
Hi Davinci,
I have diamond 9.2's with Marantz Receiver SR 5200 powered by Sonodyne Stereo power amplifier SPA 202 (Discontinued now)....
I haven't auditioned their SIA 320 Stereo amplifier....So no feedback :sad:
You can do an extended listening in the demo room & then decide...
Is any of FM using SIA320 + Wharefadle Diamond 10.1 or
PM5004 + Wharefadle Diamond 10.1 can share your experience....
(Thankyou Elango and Prosenjit.....)
