ultimateman
Hey there,
I just bought an Onkyo HT-S5400 HTIB. It is a 7.1 system and my couch is against my back wall preventing the typical configuration shown here:
http://www.audioholics.com/images/img2.jpg
Instead I'm looking to install my speakers with 5 front speakers (the additional rear speakers for 7.1 being installed as front-high speakers) as shown here:
Dolby Pro Logic IIz Details
My receiver supports the following formats: DSD, Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD, DTS High-Resolution Audio, DTS-HD Master Audio.)
Now here's my question: Which if any of these formats can truly take advantage of a 7.1 front-high setup like the one I'd like to install?
If the answer is none, then does that just mean that the front four side speakers will not have discrete sound information? And if this is the case, is there much advantage in going with a 7.1 front-high installation over a standard 5.1?
Thanks in advance!!!
