BACKGROUND
Iam a novice. hyeah:
My budget is anywhere around 2L.
I would be glad to spend them on a 3.1 + total cabling for the whole set up + Voltage stabilizer + AVR for now (want to build a 7.2.4 combo step by step)
My prime usage is movies & HD channels. Almost nil of music usage but if you people can suggest on AVR which has got good musical capabilities too ( which is rarely seen in entry and mid level) it would be icing on the cake.
Right now i will use in living room for few months but later move on to a bigger room or dedicated HT. Lets say i wud use this in my 20ft x 10ft x 10ft pent house after 6 months.
PREFERANCE
I prefer neutral, well balanced sound. They should not be laid back as I often watch action movies. So a tight bass from the Sub ( but which doesn't leave your ears in fatigue after a while) and good vocal sounding center and front floor standers to flow in mids and lows with a musically well capable AVR. (am I not asking too much?) I don't want boom boom. I want to hear a good sound stage enveloped in clear and precise sound details.
I don't mind waiting for a couple of months or more to get AVRs equipped with HDMI ver 2.0 & Dolby Atmos with a pre-out launched in india ( probably SEP or OCT).
Want to buy with bill and manufacturer warranty in india (except for cables).
Iam thinking of <1L for FF, <40K for SUB, < 30K for CC and 15K for cabling and <15 K for VERTEX HT stabilizer. If i can squeeze anything from this and add the rest to buy a AVR ( in 50K range). Ofcourse its little flexible here and there.
I wont be sold by looks but looking for black colored sheer performer in dull/ matte finish ( to avoid any minute light reflection in a dark room) from a reputed manufacturer. This applies to whole setup as much as possible.
QUIERIES
Should i go for a active/ passive sub or a combo can be done in a 5.2 or 7.2 kinda set up?
Want to build HT around speakers and not AVR as electronics keep changing but good speakers are ageless (well to an extent). Is this a good idea?
Is buying all the speakers ( & SUB) from same series and make would give any advantage as they sync well (?)
OPTIONS
FRONT FLOOR STANDERS + CENTER
1.PSB Image T6 + Image c5
2.Paradigm's Monitor 11
3.Tannoy REVOLUTION DC6T SE + VCi
4.Dali - Zensor 7 + Vokal
5.MA RX6
6.Wharfedale 10.6
7.kef Q900
8.B&W 684
9.Focal v726s
10.Polk Audio A9 + CSi A6
SUB WOOFER
1.Velodyne impact 12
2.SVS
3.Polk Audio DSW PRO 660
4.Paradigm
REQUEST
Please try to suggest all the 4 components which gel together well
Please feel free to suggest anything worth that i was missing.
I did put up a long list cos if you people suggest the best 5 of the lot i will start auditioning
I got the bucks but don't know which of these are worth. Iam saddled hyeah:
I want to pick up AVR from Marantaz (very musical but poor after sale support)/ Denon (bright and good for movies but poor in music)/ Onkyo/ Yamaha ( musical and good for movies too) only. No pioneer please. This might give you (perhaps a vague) idea to which i want to rig them.
If any of the above speaker or subwoofer series is going to be discontinued shortly i would prefer to wait for the new series as long as they are not abnormally priced than the preceded.
Not interested in used ones.
Though AVRs of newer specifications are announced of which some are in my budget, I didn't mention even a couple those model numbers as i don't want your focus distracted to electronics.
So sound first....electronics and features next.
Please correct me if i was wrong or unclear anywhere.
I know some might say my ears are the best judge but a novice is a novice and i am looking up to you fellow members to help me walk through this perfectly. Guiding is part of forum and discussion right? So please just don't say go jump and test waters. Teach me me a bit how to swim.
Thanks one and all in advance.
PREFERANCE
QUIERIES
OPTIONS
5.MA RX6
6.Wharfedale 10.6
7.kef Q900
8.B&W 684
9.Focal v726s
SUB WOOFER
2.SVS
4.Paradigm
REQUEST
