Home theatre under 60k
musiclover
I am a novice when it comes to the technics of sound. I am looking to buy a good home theatre (receiver & speakers). I like listening to all kinds of music and watch movies.
Someone please suggest a good HT, my budget is 60k. (Is it possible to get a good one for my price).
Charles
Charles
Hi Charles,
I think you should audition the Denon 1507 or 1907 av receiver along with the KEF KHT 1005 or Wharfedale Diamon 9HCP speakers.
There are many other options available but it all depends what is available in your town!
You can try the following combination :
1. Philips DVP3126 - around Rs. 3000/-
2. Onkyo Tx-SR505 - around Rs. 24000/-
3. Wharfedale Diamond 9 HCP - around Rs. 34000/-
And ofcourse ... cables.... Speaker cables, AV Cables, Digital Cable
Regards.
60 K is good amoun to get good HT system. Where you are located.
also your nick name says you are music lover so need consider that to...
check out marantz AVR+ Speaker packages + some good cable to inter connect.
happy music n movies...
Sk
I am considering the JamoS606 and sherwood RD7502S AVR and the total cost excluding the sub is coming up to 69000. Is this a good bet?
