How do I mix music?
rohitmusic
Pune
Hello Friends,
Would like to know what is the easiest way to mix music to create tracks?
I was thinking of a digital (software) solution which could allow to mix up different sounds to create some sound tracks just for fun for my personal use.
Have you tried any music mixing software that is both easy and fun to use?
(You can think electronic/techno and similar genres with intermediate voice overs)
Any pointers would help!
Thx!
You can try cool edit pro, which is pretty easy to play around with and can be easily used to layer up multiple tracks. If you're looking for different sound samples also, then give fruity loops a try!
