hey there,
im looking to step into over the ear headphone space, initially i had a budget of Rs10000/- and obvious recommendation was m50, but upon little investigation i found out about a company named Superlux, which makes affordable headphones, and heard they are quite good and rivals most headphones under $200. so I said to myself why would you spend 10k when you can get it much cheaper for around 3k(668B).
My sound preference is detail, instrument isolation, accurate bass, and would listen mostly to hindi songs ranging from Jagjit Singh's gazals to Honey Singh's Rap, so mostly everything
so my confusion, should i buy
668B for 2999/-
669 for 3099/-
or any other for 10000/-
yes i know about closed and open headphones, but havent listen to them extensively.
what would you recommend to me?
thanks
668B for 2999/-
669 for 3099/-
thanks
