How to connect integrated amplifier with Laptop ensuring no loss
Maxprocrj
India
Dear Friends
I would like to connect my Laptop to a integrated amp,will use loss less files 16/44 24/96 etc.
How can I ensure there is no loss in quality.
Please advise.
Thanks in advance
Thanks greenhorn!!
More info about Z580
HDMI Port
VGA Port
I was planning to use my Soundblaster with NAD356BEE now thinking about Cambridge Audio 651a in buit DAC
Do you already have an amp or you're planning to buy one? Personally I'd go the separates route unless there were significant savings.
Plus it seems the built in DAC of the 651a supports only 48Khz/16 bit. you can get entry level DAC's that support 96/24. But as always, do hear them out if you have an opportunity :)
Thanks for reply..
No planning for the right one......
