gudu
How to connect laptop, iPad4, mobile phone to internet via USB dongle?
What all I need to buy?
You need a modem/gateway to connect to internet.
Are you going to use your mobile phone as the modem?
In this case you need to activate GPRS/EDGE/3G/4G on your phone and connect the phone to your laptop. And run the program which connects to internet (like Nokia has Nokia suite, Sony has PC companion)
In case you prefer using external dedicated data connection, you can get the USB dongle with Airtel/Tata/Reliance/Idea etc connection. You plug this into your PC via USB and run the program to connect to internet.
Have 3g dongle.
I connect to laptop.
Now how to connect iPad 4 to get internet connectivity?
Is there a device like a 4 pin plug from which I can take 4 connections?
Wont be using phone as modem.
Please suggest.
Or if you do not want to spend on new hardware then you can use your Laptop as a Wi-fi router. You can use softwares like mHotspot , Marify, Virtual router in your laptop to share the connection with other devices through Wi-Fi.
netsh wlan set hostednetwork mode=allow ssid=MyHotspot key=12345678 keyUsage=persistent
netsh wlan start hostednetwork
netsh wlan stop hostednetwork
This should not remain limited to the laptop alone, in fact if the cell phone support wifi tethering then also this can be leveraged by just activating 3G on the sim. Similarly iPad3 onwards have built in Personal Hotspot capability to tether the internet of the sim inside it.
I have the exact same router and using it with my Mtnl 3G USB dongle. It should work with airtel too. I won't recommend it though. This router is a piece of crap IMO. It's barely 12 months old and wifi antenna has already stopped working. Only getting less than 10 feet of wifi range now. Even before that I've had so many connection issues with this. Had to physically reboot it every couple of hours as it simply stops working. My experience with Netgear routers has been much more positive in comparison.D-link
DWR-113 3G WI-FI ROUTER
This one has one usb port, so there me have to put the 3g dongle, but question is will I be able to collect laptop, ipad, iphone through wifi?
does this fit in the requirement?
Please tell.
Hi gudu, I did not notice the posts on this thread while replying to your pms. Nevertheless I hope you are decided now on what to buy. Just be aware of the reviews and the compatibility of your airtel 3g dongle with your router. Hope the wifi coverage area is not large
^^ Connect your 3G dongle to Windows7 or 8 laptop and access internet. Then use the method I described earlier to share this internet connection through laptop wifi. Your other devices will see this virtual hotspot you created and can they use the internet connection.
