I have the following devices:
1) Samsung LCD TV - LA40C550
2) Onkyo 3400 Receiver
3) Motherboard that supports HD Audio/ Video - Intel Motherboard DG965RY
4) Nvidia Graphics Card with DVI Output
Somehow i can manage to connect the Computer to TV for watching Video, by connecting with HDMI cable using DVI-HDMI dongle...However, my main intent is, how to achieve 5.1 surround...
Is it possible to connect the stereo output of my computer (green color) to L/R input of the AV receiver by purchasing stereo to RCA cable and still achieve 5.1, since my motherboard supports 5.1...
(I always thought that 5.1 is possible either through Optical or coaxial, but somewhere i read that, even after connecting to L/R inputs it is possible only if the Motherboard supports... not sure..?????)
Link to the Manual of my Motherboard
http://downloadmirror.intel.com/15056/eng/DG965RY_TechProdSpec.pdf
Here is the gist of the manual wordings that talk about this
Advanced Digital Display (ADD2/MEC) Card Support
The GMCH routes two multiplexed SDVO ports that are each capable of driving up to a200 MHz pixel clock to the PCI Express x16 connector. The SDVO ports can be pairedfor a dual channel configuration to support up to a 400 MHz pixel clock. When an ADD2/MEC card is detected, the Intel GMA X3000 graphics controller is enabled and the PCI Express x16 connector is configured for SDVO mode. SDVO mode enables the SDVO ports to be accessed by the ADD2/MEC card. An ADD2/MEC card can either be
configured to support simultaneous display with the primary VGA display or can be configured to support dual independent display as an extended desktop configurationwith different color depths and resolutions. ADD2/MEC cards can be designed to support the following configurations:
TV-Out (composite video)
Transition Minimized Differential Signaling (TMDS) for DVI 1.0
Low Voltage Differential Signaling (LVDS)
Single device operating in dual channel mode
VGA output
HDTV output
HDMI/UDI support (when used with the HD Audio Link)
Let me know if there are any other simple and feasible connections...
Thanks!!
VGA output
HDTV output
Thanks!!
