Hi Friends,
Recently i observed that the normal power strip (or power extension board) which I was using, was affecting the final sound to some extent. Different power strips changed the sound differently. Some power strips have a fuse in them, some have an individual switch for each socket and some have a single switch for all sockets.
So I created a custom power board with 4 sockets and 1 switch only. (instead of 4 individual switches). The top board, sockets and swtich was of Anchor Roma brand. Internal wiring was of Polycab wire.
Now I needed to add more connections. So I attached 3 pin connector. But I still think that is not ideal. I felt different 3 pin connectors also affected the sound sometimes.
So I am thinking to build a bigger power board with around 8 sockets and either 1 switch or max 2 switches. I do not want to put individual switches, prefer to keep the path simple.
Yesterday I came across an article which says about the INTERNAL WIRING inside a power strip/board. It states something about SERIAL WIRE vs STAR WIRING. It also says about SEQUENCE Of items plugged in and how it can impact sound to some extent.
So I wanted to know your opinions and what you think is a good approach for internal wiring. Also any preferences of the wire to use for internal wiring, and any preference for the brand of sockets and switches.
https://www.hifi-advice.com/blog/au.../power-extension-blocks-normal-or-star-wired/
